Brief Description: Cowling engine cooling intake ring sanding...
I decided to work on the smoothness of the engine cooling air intake rings and cowling interface. I sanded all the sufaces smooth and cleaned up the intake rings of mold release wax and epoxy. Once cleaned up I fitted the upper and lower cowling and intake rings and fitted the rubber interface tube between the air intake rings and plenum. To finish off I worked on contouring and drilling the reglassing I had done on the horizontal to vertical stabilizer fairing as well as countersinking the screw holes.
Engine cooling plenum to engine cooling air intake ring rubber interface tube fitted
View of the right engine cooling air inlet with inlet ring and plenum fitted
More horizontal to vertical stabilizer fairing finishing work carried out
